235K tranny fluid?
very rarely do "japanese" cars don't have a transmission drain plug lol
Most of them do, in fact, have a drain plug. Including the OP's 2005 Matrix. It's the "American" nameplates that are too cheap to include a drain plug. The Euros are hit or miss.
Every Japanese car I've worked on had a transmission drain plug. Multiple Hondas, Toyotas, Subarus, and a couple Nissans.
American cars with no drain plug: the final gen Grand Am, 3rd and 4th gen Firebird/F-Body, Mk1 Focus. The only American car I have experience with that had a transmission drain plug was the Saturn S-Series.
When Ford owned Mazda, they often used the same engines and transmissions across both brands, yet Mazda included a drain plug but Ford didn't. Example: Ford Fusion (no drain plug), Mazda 6 (has a drain plug). The Focus used the 4F27E with no drain plug, but Mazda included one. Since they use the same transmission with the same pan, you can get a pan from the Mazda dealer and install it on a Ford with that transmission (or use an aftermarket pan).
In most Hondas, changing the ATF is *easier* than changing the oil :D
I disagree that you just want to slam it in there. I’ve seen on very old and under serviced transmissions where issues do arise. For whatever reason.
I do feel that the slow methodical process did swapping in new fluid is a good idea if viable. It usually is viable with a dipstick extractor or a drain plug.
It also helps because while some vehicles like Mercedes have easily accessed torque converter drain plugs, most don’t. A pan drop and filter change could leave many quarts/half(?) the fluid in there. Doing a few extract and fills helps dilute the old fluid so the remnants are newer too.
There’s no doom and gloom. Change it! But a small initial/few changeout to get some new detergents and dispersants in there is best practice imo.
Absolutely. Take a measured, gradual approach to the drain and fill to get a better overall replacement and minimize sediment or wear materials. I was talking about the old horse that after a trans has had oil for too long, it is past the point of safely changing it. Of course, there is never a meaningful explanation!
2006 Toyota Matrix 235K miles. I have owned this for the past five years, purchased with 220K miles on odo. Tranny fluid looks dirty, smells fine. Should I drain and refill or just leave it alone. Manual says changing fluid is “unnecessary” under normal driving conditions. Is it better to let well enough alone, or should I give the old girl a shot of new fluid?
I would do a drain and fill ONLY
