I have 90k mi. on my A343F transmission in a 1997 Toyota Landcruiser. It had it's transmission fluid drained/filled with Mobil 1 synth. ATF at 30K and 45K mi. It had a full fluid exchange with Mobil 1 synth. ATF at 60K mi. At this time, the tech doing the fluid exchange underfilled the transmission by more than 1 Qt. I drove it this way for the next 15K mi, during which time (rarely) when I could come to a sudden stop and then accelerate, the vehicle would not move and then it would suddenly and harshly "kick" into gear. I later realized this was from fluid starvation to the transmission since it was low on fluid. I filled it and the problem stopped. Stupid to let it go this long, bu that's what happened.
I did another drain/fill at 75K mi., and I finally dropped the pan, cleaned the pan/screen/magnets, and then did a fluid exchange at 90K mi, so this was the first time the pan was dropped. When I examined the pan, the fluid looked bright red and smelled fine, the magnets were coated with grey particulate matter, and I saw some fine shiny metallic particles in the fluid. Is this normal considering it is the first time the pan has been dropped in 90k mi, or do you think this is a result of the previous fluid starvation condition? I have no problems with the transmission right now- no strange noises and it shifts fine. Should I be concerned about permanent damage?
