- Joined
- Aug 20, 2024
- Messages
- 12
Fell down the engine oil rabbit hole when I discovered my vehicle was low on oil, and I had to top it up. I have a 2017 GLC43 AMG with 88,000 km on it. Couple weeks later, I took it to the dealer to get serviced and they changed the oil, putting in OEM 5W-40. I moved recently, so the place that did my oil change last year put in 0W-40. Given these were both dealerships that did the service, I was a bit surprised by the discrepancy (going independent next time). Speaking with someone at the old place, they said it was probably supply reasons for why the other place didn't stock the 0w-40 version recommend for AMGs.
Anyway, both meet the 229.5 spec, which is what matters. However, my vehicle also lists 229.6 spec oils, and 229.6 only come in two weights (0w-30 and 5w30) vs the four weights offered at 229.5 (0w-, 5w-; 30, 40). There are a lot fewer oils that meet the 229.6 spec too, but if it's somehow better, shouldn't I try them next oil change in 6 months?
There doesn't seem to be much discussion of the different specs here, but one thread from 5 years ago gives the Lubrizol comparison card using the 2016 versions of the specs, but those specs seem to have changed as of 2019 and later 2022. https://bobistheoilguy.com/forums/threads/mb-229-5-vs-229-6.316514/post-5234799
As you can see, the 229.6 spec (2022) has shifted from 9 for fuel economy to 7, but has increased from matching 229.5 at 7 to a 10 for oxidative thickening. Wouldn't that suggest it's the better spec to use now? And, what about the shift from 40 to 30? Is it better to stick with 0w-40 (a favourite of many) or switch to 0w30 or even the 5w30 to meet this newer 229.6 spec?
list of 229.6 spec oils: https://operatingfluids.mercedes-benz.com/sheet/229.6
list of 229.5 spec oils: https://operatingfluids.mercedes-benz.com/sheet/229.5
of the 229.6 oils, Ravenol seems to have the most that meet it, and that is most avaible: Ravenol FDS SAE 5w30, HSV SAE 0W-30, SSV SAE 0W-30. There's also LIQUI MOLY Special Tec B FE 0W-30. Those seem like the easiest to find for me.
