Originally Posted By: Pop_Rivit
Can someone point me to information about the failures, damage and reduced longevity caused by running an Xw-20 in the summer months, even on a vehicle that sees high outdoor temperatures and cars that see heavy loads?
I see a lot of suggestions (by some) that a 30 weight is better for summer or "tough" use, but I don't see any of it backed up by real proof.
That assumes the vehicle is spec'd for a 20 weight.
I'd love to see the actual proof-it would be interesting reading.
I hear a lot of people on this forum talk about the need to use 30wt instead of 20wt, when towing. So here's the question...
Hasn't Ford, in their 1/2 ton pickups, spec'd 20wt for several years? I wonder how service trucks are performing with 20wt. For instance the oil and gas industry uses thousands of these trucks in the oil field. Also, cities and counties across the nation have fleets of these pickups....
Surely there is data somewhere.....????
I do have to admit that I would lean to 30wt in summer and when towing....so I am in that camp until some data surfaces that proves it wrong.
