"20W-50 is too heavy for that small engine"
bunnspecial
US
Originally Posted by ka9mnx
Why do you think you need "plenty of ZDDP"?
Flat tappets, plus a camshaft is $300 and an engine-out job. I want to be sure there's enough there to not have to worry about it.
montreal ,canada
$300 sounds like a super bargain for what you're describing.
New Zealand
The Marina came in lots of versions here, with A, B, N and O series engines. You are lucky it's got the BW35 - BL made BMC use the Triumph Toledo manual box to get syncro on 1st. It was a horrible, horrible thing, and a lot were converted to the BMC box...as used in the MGB, which in the real (rest of) world was also used in every BMC badge car including vans like the J4. BMC's were pretty good cars, BL totally destroyed the brands reputation.
California
Nothing wrong continuing to do what has been working for you. If you are really curious, try a good 10w40 and see if it cranks or starts easier, revs more freely, consumes oil, leaks oil, or any other noticeable difference.
i run motorcycle, castrol go 20W-50 jaso ma2 oil in my 1275cc classic mini. these little sump sharing 4 bangers need all the thickies in order to stay alive.
