Ram finally revealed specs on the Ram 1500 REV today at the New York Auto Show.
Other tidbits:
- Multi link independent rear suspension
- Front axle disconnects (some EVs use these already)
- Electronic-locking rear differential
- .340 coefficient of drag
- 7.2kW power supply in bed. 3.6 kW in frunk.
https://media.stellantisnorthamerica.com/newsrelease.do?id=24777&mid=1
- All-electric, zero-emission Ram 1500 REV to be offered in two choices:
- Standard 168-kilowatt-hour (kWh) battery pack with a targeted range of up to 350 miles
- Optional 229-kWh large battery pack with a targeted range of up to an unsurpassed 500 miles
- Towing up to 14,000 lbs. and payload of up to 2,700 lbs.
- Adding up to 110 miles of range in approximately 10 minutes with 800-volt DC fast charging at up to 350 kW
- Ram 1500 REV XR with class-shattering range to follow
- Built on new STLA Frame body-on-frame architecture designed specifically for full-size electric vehicles featuring a body-on-frame design that incorporates the battery pack efficiently
- New powered front trunk (frunk) offers best-in-class 15 cu.-ft. of storage
- Other targeted performance figures include a 0-60 mph time of 4.4 seconds, 654 horsepower and 620 lb.-ft. of torque, up to 24 inches of water fording
Other tidbits:
