2022 Toyota Camry Hybrid - 10K Mobil 1 0w-16
Monterey, CA
~9700 mile oil change interval on a Camry hybrid. Looks great!
I sacrificed my moms Camry for this and will now be going 10k if not more on my 2022 camry non hybrid.
Note the amount of Moly. That's why I want an oil with lots of it. Thats why I put some Liquid Moly in my Subaru Forester XT and Use the Delo 600 which has like 700ppm moly.
TGMO 0w-16 is also loaded with moly. The big question is, what type of moly is each oil using.
Nice run. I'm interested in your results. Decided to dump the factory 0W-16 and run traditional synthetic 0W-20 in my first oil change that I did a little before 5k on my 2024 Sienna which has the same engine I believe but has to lug around a much heavier vehicle. I might take advantage of Toyota's included oil changes when I get to 10k but I'm a little leery of the 0W-16 since I'm pretty convinced the change from -20 to -16 was for CAFE numbers and certainly not for longevity of the engine though the 0W-16 oils are being formulated to cope to some extent with the higher potential for fuel dilution, water condensation, etc.
Does it matter if the wear is very low? Id argue no it doesn't. I run 15w-40 rotella on my motorcycles calling for 50w and tests came back fine too.
UOA’s don’t tell the whole story. It is a snapshot of data in time. And I would say possibly inaccurate data based on Blackstone’s practices. But if you’re good with the results then go forth. To each his own.
