Just venting. Had the car in for state inspection at around 65K and the shop gave me $1500 in things that "NEEDED" to be done.
- Front/Rear Diff Gear Oil --> Done
- CVT Fluid --> Done earlier by me
- Brake Fluid --> NOPE. It's good.
- Spark Plugs --> Done... shop price
I've never had a worse time changing plugs on any car, more specifically the driver side rear one. Good Lord. I must have tried every wobble and extension length I have, alternating between 1/4" and 3/8" ratchets. You have to insert one tool segment at a time due to super tight clearance issues with the body. I watched a couple YouTube heroes... didn't see that I was doing anything really different. It took hours and I am glad it's done...
I used factory gear oil and the recommended NGK plugs. Spent less than $200 on fluids, plugs, and a T70 socket for the front diff. Right now not sure I'd do the plugs myself again... but give it enough time and we will see.
