You could not floor the pedal from a stop light. It would spin and engage traction control. You had to be a bit careful applying the throttle. This was with the 8 speed, the heavier 2016 chassis, and about 200lb added from my expensive BDS lift and diamondback tonneau cover. Pulling out of a gas station or something where your wheels are not straight the wheel spin was easy at part throttle. The engine sounded amazing and felt like it had great power. The fuel economy was also very good for what it was. On a good day at 70 mph you could get an honest 20 mpg. This is with the 35 12.50 20 michelin tires. lift, and a black bear ECU tune for the tire size and whatever else they do for a stock tune on them.
So from my ownership experience (69k-79k miles) i can say that the gen V 6.2 is a fantastic performer and very efficient.
Now why would the Hellcat TRX get way worse MPG?
1. Hellcat is Port Injected and 9.5:1 compression. The N/A L87 6.2 comes in at 11.5:1 with direct injection resulting in greater efficiency.
2. Supercharger creates some drag. In the most fair comparison, GM LT4 vs LT1 engines, the LT4 gives up 4 MPG combined in the Camaro 10 speed platform. Even with 5.7 and 6.4 N/A RAM VS GM comparisons the GM small blocks usually win by 1-2 mpg.
3. TRX is REALLY BEEFY in construction, frame, ect. It weighs around 1,000lbs more than a typical GM and ford half ton.
4. GM is 10 speeds vs 8 speeds in the ram, this might not add up to much at all but something of a fuel save.
5. No cylinder deactivation, i see this as a huge pro to the Hellcat for durability but in gas mileage terms its a penalty. If i was on a flat level road at 35-40 mph in the 2016 6.2, it would go V4 and produce 35+ mpg real time fuel economy readings. At 3.1 liters and low enough speeds that drag wasn't a big deal, i believe it. The computer MPG was always very close to hand calculated at least on my truck.
6. Overall Power of the TRX, as you floor a 700hp engine it will burn a lot more fuel than a 420hp one. Being more fun and literally faster you are much more likely to over acccelerate and hit brakes more.
Anectodally, many people have reported bad MPG in the TRX and nobody is surprised.
So it would be very interesting to have a direct long distance comparison between the TRX and this new ZR2 but my guess is the GM would beat it by about 25%. 10 city hellcat vs 12.5 city ZR2. If the hellcat is getting 14 highway the ZR2 might get 17.5 right next to it at the same speed. Just my guesses as to what a real world side by side might be.
While i am pulling numbers out of my [hat] lets suppose two people buy the trucks and own them for exactly 100k miles doing the same driving. Some city, highway, towing, desert fun and offroading, and my 25% estimate is accurate. Assigning a lifetime average to a TRX might be 12 MPG and 15 mpg for the ZR2. 8333 gallons in the TRX, lets say $4 a gallon lifetime average price gets you to $33,333. If the ZR2 can average 15 in the same use thats only 6666 gallons $26,666 dollars. That is between 6 and 7 grand per 100k miles of use, not a huge deal for someone affording a new expensive truck, but its something.
TRX may never reach sitting on the lot for sale with a discount to MSRP status but the Silverado will. If the TRX stays low volume and hard to buy for less than 120k then all this discussion is useless.
Cost and MPG aside, the TRX will be the best truck at a few things. 1. Desert running, obviously, it is the king. 2. Being cool/showy/fast.
The ZR2 will exceed at being a well rounded vehicle that can offroad well and low and moderate speeds. It will be a truck you will use for everything and not need to be so concerned about it being collectible or rare or anything like that.
It comes down to, are you buying a toy or a well rounded vehicle? I think outside of a some fun romps in the dirt and possibly getting some tickets on the street the fun factor of the TRX will wear off and you'll just be hauling the extra weight and pumping the extra gas. The real winners here are those who originally ordered the TRX, had their fun, and flipped it into this crazy market.
