SilverFusion2010
Nope, too shortIs this your oil filter? https://www.amazon.com/Extended-Fil...ocphy=9009565&hvtargid=pla-968767783385&psc=1
I'm going to do the pics and filter change today if nothing sideswipes me.
Changed oil and filter last night. 6qt Mobil 1 Full Synthetic 0w40 and oem filter
Nice, and good choice on the oil. You can square another 0.2 quarts in there just for good measure (it calls for something like ~6.13 quarts). That's the same oil filter as I use (look at my signature). In fact, I just bought 12 of them for $112 shipped from a Florida dealer. Turns out that they're cheaper for KIA than Hyundai, so I'm going to use KIA filters from here on out. Your old filter looks fine. Mine was sparkling in the sun when I did my first oil change, and there were particles in that plastic housing as well. Took a while to clean everything. Let me know what kind of fuel mileage you're getting with the new oil![]()
No way on earth anyone could detect and ascribe a real-world fuel economy change to the oil. Considering that gasoline varies in energy density by up to 4% even at the same gas station that puts a much smaller change down deep into the noise. Add in all the other vagrancies of daily driving and any observed change is impossible to attribute to one isolated variable.Let me know what kind of fuel mileage you're getting with the new oil![]()
The problem is not measuring something, the problem is ascribing it to one variable which in this case is utterly impossible.
We really haven't seen the viscosity degradation with current Mobil 1 0W-40 have we? That was a while ago, at least one or two formula iterations.I agree with you. Still, I was wondering if @SilverFusion2010 will experience any meaningful change. IMHO, he won't. The Mobil 1 FS 0W-40 is basically 0w30 in disguise. In every VOA I've seen of this oil, the cSt @ 100C is towards the top end of a 30-grade oil. I think that's why it lost its BMW LL01 certification, along with Castrol, Pennzoil, and other 0W-40 oils. It's almost like all of these manufacturers decided to make 0W-40 thinner when they reformulated it a few years ago and either shear down to a 30 grade as soon as possible or ship it as a thick 30 grade in a 40-grade bottle as Mobil does.
Just bought a 2021 Kia K5 GT. 2.5L turbo making 290hp. On prior vehicles I ran fram ultras out around 7500-10k miles. This one requires 3k changes under severe service... and since I'm enjoying the 290hp...
Basically, should I go with the orange can fram and save myself some money, or is it worth shelling out for a fram ultra every 3k?
EDIT
Fram doesn't offer a filter for this engine. Just finished up a live chat. So now I need filter recommendations. TIA
If this engine is a GDI, check for fuel contamination in the crankcase. If you encounter a fuel odor or have the oil analyzed and find over 2% of fuel in the oil, follow the 3k routine.
The approvals are based on HT/HS anyway, not a grade.
All approvals specify a minimum HT/HS but that's not the only criteria for approval. My point was that it's not based on the grade (some approvals are starting to disregard grade) and neither is it based on a winter rating. There are many criteria an oil has to meet for an approval. To say it is "viscosity-related" and then infer it is related to the winter rating is not based on anything factual. Even if you wish to promote the notion it is for wide viscosity range oils that wouldn't apply to a 0w30 oil as opposed to 0W-40.Right, so Castrol EDGE Euro (API SL) 5w30 with an HTHS of 3.5 carries a BMW LL01 approval, while Castrol EDGE Euro (API SN) 0W-40 with an HTHS of 3.7 doesn't.
Actually looking at this: https://360.lubrizol.com/Specifications/BMW/BMW-Longlife-01
It seems that it's viscosity-related, as only 5w30 and 5W-40 oils can get LL01 now.
Cartridge looks fine, wonder who makes it for them? Mahle has made H/K cartridge filters on other models, eg. 3.3L engine.
What the oci/fci?
The aftermarket will catch up, though if history an indicator, some will just use the oem in their branded box. At least for awhile.
Yeah, economies of scale keep cartridges higher than spin on anyway. Until and unless the application becomes popular enough to manufacture or rebox, they may not wade in. Fram reboxes the Mahle H/K OEM for the 3.3L engine. Extra Guard CH10855. Same cartridge.The aftermarket hasn't yet caught up, it's not a money maker I guess. Too many pieces to include in the kit for most manufacturers that are used to the easy money that a regular spin-on filter brings in.
It's the European manual probably. Can you please post the link to it? Thank you.The KIA K5 manual recommends Total Quartz brand motor oil. That's a new one...
