2020 VW FACTORY FILTER CUT OPEN
In the shop
Good Evening again folks 🇺🇸🇨🇦
This filter was on a friends 2020 VW Jetta with 4cylinder engine for 4,400 miles. I installed Castrol Pro 0w20 oil he brought that meets the VW spec and another VW filter. Looks ok to me.
Thanks for the C&P Adam.
This is the somewhat rarer FFA filter.
It has some similarities and some obvious differences from the more common MHL filter.
Every service one i have seen is MHL...
Robert: you are welcome sir 🇺🇸☮️🇨🇦🍻
thanks for the info about the filter sir
Wire backed media ... probably full synthetic media then. Looks like a nice filter, thanks for the C&P. (y)
Nice. I just noticed this thread. These filters feel very heavy and solid, nice to know the internals look good too! Thanks for the cut and post.
Yes, the 1.4T has a easy to find PH3614 sized filter or euro equivalent(higher bypass).
I run the XG3600 oversized on my 1.4T. The XG2870a is the equivalent sized euro filter.
VW, in a few models, are beginning to use Full Synthetic media(something MH learned from Purolator/Wix acquisitions). Need to pull media apart for a looksy. If supported by metal/plastic mesh, could be full or high percentage synthetic media.
The made in Turkey filter is the factory installed filter. The dealer sourced filter is not made in Turkey.
