Originally Posted by glock19
Originally Posted by Ws6
"By the numbers", the BMW should be better able to abruptly change direction at speed...but it just isn't so.
Why?
The BMW has better weight distribution, wider tires, and a longitudinally mounted engine. It should easily have handled superior based on static data. Not so, in reality.
A X3 is 1,000lbs heavier than a CX-5. If they weighed the same, it would be no contest.
Okay, how about the fact that a Civic Type R is much faster about the track than a 370Z? Go look at the weight distribution on those two and the lap times they turn on the same track. Eye opening. The civic has over 60% over the front axle, and weighs within 250# of the 370z, which has a longitudinal engine and is only pushing 53% or so over the front axle, AND is rwd...AND has almost 30hp more. Go look at them lap times!
There is more to handling than where the engine is and which way it faces...
https://fastestlaps.com/comparisons/4j0a9ozdieh4
Ps, that civic R lapped the 'ring in 7:43...again...more to it than engine location.
Why?
