I went through a similar search for my 2010 fj cruiser.
What i decided....
The ujoints probably wont be ruined if you use a grease that has moly in it. These joints are well built and many of them go without lube for tons of miles. Most places wont even realize a brand new vehicle has any grease points on it, let alone 6 of them. Just about anything will be fine for these. Just keep them greased. If you insist on the spicer grease, remember its not a lithium grease...so watch out for compatibility.
The moly requirement is not needed on the propeller shaft. Again, anything will do fine here. Many will strongly disagree with this, but its true (with some caveats) just about anything will work here, but you wont get through your 15k service interval. My toyota has the famous "clunk" if i dont keep it lubed. Moly grease will last longer, but my belief is that the moly only masks a low or no grease condition. Remember moly is a dry lubricant. I used lucas red tacky and it would go about 4k miles, better grease will last longer, moly grease will seem to last longer.
Dive into some grease product data sheets and look at the specs. And dont go 15k withoit lubing the driveshaft!
What i decided....
