My wife against my advice picked out a 2018 VW Tiguan 4motion brand new with the SE package includes panoramic sunroof , leatherette heated seats and touch screen CarPlay.
Initially it was good except for leaking into car up front. It was found during high pollen year the drains were clogged and dealer fixed. They also cut the ends of drain pipe which apparently later was a TSB.
We did a 10k OCI with Castrol VW 508 spec. Between new and now (185,000 miles) was simply maintenance by book with 2 full brake replacements and 2 tire changes (Bridgestone RT45).
The only issue hit was at 151k the car would go into limp mode and not go more then 20-30MPH. Turned out to be an extended warranty issue(150k) with ignition wire harness that dealer charged $900 to replace.
We love the way it drives and still delivering around 31MPG mostly highway summer and drops to 28 MPG winter. It uses about 1 qt oil in 5k miles so dump supertech synthetic as topper.
The original suspension is a little creaky now.
Believe or not this VW has had less issues then her previous 96 Civic and Subaru Legacy by a long shot.
It’s rated as not reliable by consumer reports however we must be an outlier. We plan/hope on driving another (75k+) as we have three year of college to pay for. A friend who is European knowledgeable with lift in garage since 151k wrenches it for $50/hr + parts so maintenance has been cheap.
It now gets Motul oil in a $85 FCP kit he orders to change up oil.
