F Fordiesel69 Joined Sep 10, 2005 Messages 2,811 Location Erie, PA Nov 1, 2023 #1 Owners manual states Mercon ULV but it does not break it down as to what transmission was offererd. Shops say to use LV in 6 speed and ULV in 10 speed. Ford parts says ULV in all 2018 f150 regardless of transmission. Very confused.
mattd Joined Oct 3, 2010 Messages 3,195 Location RI Nov 1, 2023 #2 6r80 should be LV. 10 speeds use ULV
dnewton3 Staff member Joined May 14, 2007 Messages 14,029 Location Indianapolis, IN Nov 1, 2023 #3 mattd said: 6r80 should be LV. 10 speeds use ULV Click to expand... Correct, as best I understand it. All the 6R series (6R80, 6R100, 6R140) use LV. All the 10R series (F150 and SD series) use ULV.
BISCUT Joined Dec 28, 2011 Messages 5,635 Nov 1, 2023 #4 Mine is a 15 6R80 and LV is what I've used and what the manual spec's. Hope this helps.
S Sumboodie Joined Mar 31, 2012 Messages 1,497 Location Palmer, AK Nov 1, 2023 #5 This is what the fleets use here, or the Motorcraft branded stuff. Attachments 16988758072216619877793025092499.webp 87.1 KB · Views: 81
R ripcord Joined Apr 1, 2020 Messages 11,570 Location Pacific Northwest Nov 1, 2023 #6 nate379 said: This is what the fleets use here, or the Motorcraft branded stuff. Click to expand... VersaTrans is made by Phillips which has been the historic provider of most Motorcraft fluids, so likely the same or better than factory.
S Sumboodie Joined Mar 31, 2012 Messages 1,497 Location Palmer, AK Nov 1, 2023 #7 ripcord said: VersaTrans is made by Phillips which has been the historic provider of most Motorcraft fluids, so likely the same or better than factory. Click to expand... Yes. Few shops use the Motorcraft to avoid headaches with warranties. Easier for Ford to weasel out if paying with xyz oil was "wrong" as an excuse.
