2017 Miata - Mobil 1 ESP 0w30 - 6500 mi OCI
Columbia, SC
A nice, boring report for my Miata. Daily driven, almost purely highway miles. My daily commute is about 80mi round trip. I'll probably stick with ESP 0w30. It's cheap, and readily available at Walmart.
Nice report! I love the Mobil1 options available now at Walmart. Makes everything easy and reasonably priced.
  • Like
Reactions: hrv
Always 6607, until last month. Just installed Ultra 7317 with this past oil change, and threw in 5qts M1 ESP 0w30.
I recently cut open a 6607 from a Nissan Quest and was SHOCKED by how little filter media was in there. (Should have taken pics but wasn’t in the mood, just inspecting 6-7 customer’s filters for my own pleasure) It’s a VERY Tiny filter. I would avoid it, honestly after seeing the internals.
I now switched to the normal sized 7317 moving forward. 👍🏼
Try 10k miles for your OCI. The lube is in fine shape. The contamination and wear data also indicate it's certainly doable.
I second this, if the OP is literally doing mostly highway cruising on a daily basis. It’s a perfect candidate for extended OCIs 👌🏼
