Originally Posted by BucDan
Originally Posted by edyvw
OP. Take it from another Audi owner. If you can, get Pennzoil platinum Euro 0w-40 if they have it at walmart. Then PP Euro 5w-40. Then Castrol 0w-40. Then Castrol 5w-40. If you want boutique for the American market, then Motul 8100 Xcess or Xclean or Liqui Moly leichtlauf all 3 in 5w-40.
Keep it simple.
Thank you sir, I believe our local Walmart has a few of these.
Castrol 0W40 would be my preference before any of these oils. PP Euro is hard to find at decent price and it is not anything special. For PP Euro you have to look at it at Auto Zone or AAP on sale. I use it in BMW and it is smooth, but it seems consumption is substantially higher than BMW TPT 5W30 I had before.
Sucks to hear about the oil consumption. The only worry I hear about Castrol nowadays is that it leaves behind varnish in the block. I doubt it really affects anything, but that has been the main complaint of it. Heck it could be a good thing if it leaves on a hard protective coating; wood furniture is coated to protect it, so why not an engine block? I've stayed away from Mobil 1 Euro for my car. I've been tempted to move away from Motul for a more readily available oil, one that keeps the engine smooth and quiet, but so far, Motul has treated me well. Hard to break a habit. I was on Castrol OE Pro, but I've switched to Motul after hearing good things about it. I've only ever considered PP Euro as a replacement for me.
Audi purchased.. let the fun begin !
i hope you enjoy it! Read through the manual. Audis are very techy.
I have never heard of that varnish thing. Castrol 0W40 is approved against all Euro approvals except LL01 (it seems new update of LL01 eliminated bunch of 0W oils, if not all).
Will see about PP Euro. One problem with BMW N52 engine is electronic oil level measurement, so it could be that I did not put to max but just on border between max and 3/4 full. After 1000 miles it drops to 3/4 full. Reason is that I mixed some leftover TPT. So, will see over 5 k how much it uses.
