I had another rust belt belt victim today. My daughter's 2015 Versa sedan with 56K miles on it. I had noticed some oil stains on my driveway where she parks . Popped the hood as soon as I could and noticed ATF all over the place. I got it up on ramps in the garage to find where it seemed to be seeping from the steel portion of the ATF cooler supply line where it runs along the radiator support and snaps into place on the lower fan shroud. When I wiggled it it really let loose and ATF began running out of it. This would have stranded her for sure.
These are cheap cars and the underpinnings, even though being painted/treated rust unbelievably quickly. Especially any fasteners. There's spots on the transmission pan that are rusted/bubbled so badly I don't think the pan would last another year. The bolts that hold the engine oil pan and trans pan have some bolt heads that are rusted mostly away. I've treated this vehicle with fluid film and woolwax over the past 2 years we've owned it, but given the underside is fully exposed, it all wears off quickly. I did not treat the ATF cooler lines.
I replaced the cooler line assembly with a section of 5/16" ID rubber hose I got from Napa. It took 3 parts stores to fine this size, which sucked and they all want ~$30 for a gallon jug of maxlife ATF, so I had to make a trip to wally to get a jug for $17. Napa charged me almost $14 for 3 feet of Gates 5/16" oil line/hose. This 2015 Versa has the old school 4spd AT as opposed to the CVT. Either model uses the same transmission fluid cooler lines FWIW.
