2015 Impala V6 exhaust leak
Using a smoker through a spark plug hole, I found where the leak is. This is just down from the forward converter....can this be repaired or does it need a new Y-pipe?
Has anyone welded this area? Doesn’t look like a fun weld given the two materials.
Is the flex portion integrated into the Y-pipe?
I appreciate any input.
If you can replace just the flex pipe, get one that's 304, so it wont rust again :D
Amazon and other sites have 304 flex pipes.
Muffler shops can replace the flex pipe. They do it all the time.
most likely the repair without replacing the whole pipe will go like this
flex is cut off flange and cut farther down the pipe, new flex pipe is welded in with maybe a couple inches of solid pipe welded to the flange then connected to the existing exhaust. it will move your flex a few inches down the exhaust path, but this is of no concern.
thats the repair I'd shoot for.
