2015 Altima no start key fob issue - Help!
Los Gatos, CA
My friend's 2015 Altima has the infamous problem of not recognizing the key fob.
It is not the fob battery; I replaced it but doubted that was the problem as the door locks and everything else worked.
When working correctly, the fob onln needs to be inside the car, even in the trunk, to be recognized.
For the last few months Dan would hold the fob next to the start button and the car would start.
Now it is very intermittent; it does not recognize the key in the morning but does in the afternoon.
I suspect a major module or even the ECU. Not sure how to check...
Any guidance is appreciated.
Start with the key.. Is it possible the key is the problem? Is there another key your friend can test with?
Doesn't it have a slot in the dash for the fob?
My Suzuki and Mitsubishi Outlander have the same issue. The Mitsubishi will itermittently flash 'key not detected' while the engine is running, car in park and either front door is opened then closed. Holding the fob close to the start button usually clears the warning.
Gobs of sehnsucht for the days of a key and column ignition switch.
No warning message; there is no communication. It is like the key fob is not in the car.
I will go over in the morning and do another test. He says it does not work in the morning but does in the afternoon.
You have to put the fob next to the button for any chance...
I've seen on Youtube striking on a module under the dash may "awaken" it.
On Hyundais the problem seems to be slight bit of corrosion on the fuses controlling the key recognition and always hot base system. Happened to me with my PB start Gen Coupe and also on the older Accent for the radio.
The fuses check out as good but if you notice any difference in voltage on the other leg then there is some resistance there.
That's not a good idea. Lose that one fob and chances are you have to get the car towed to the dealer to have the security module replaced in addition to a new fob. A $200-$250 fob turns into $800 or $900 repair.
Absolutely. Not to mention if it's your primary vehicle, you'll be needing a rental. Around here, at least, shops are backed up a week before they'd be able to get to it.
When you put the fob near the button, it is read by a near-field radio which is a completely different system.
There are three types of communication:
1 outside the car to unlock the doors
2 inside the car (e.g. driver's pocket) to allow starting
3 near the button as a reserve way to allow starting
I don't know if 1 and 2 use the same radio system or not.
