Originally Posted By: rslifkin
A friend of mine has a 2010 TDI 6 speed Jetta wagon. He's up to around 70k miles, IIRC. It's been great so far, no mechanical issues. Starts great in the cold, warms up only a little slower than my Jeep once it's running. His only real complaint with the car is that the ECU programming is super-conservative around idle to keep emissions down, so if you dip the revs more than 100 rpm below idle on take off, it just stalls suddenly and violently as the ECU cuts fuel.
He averages 40+ mpg in mixed city / highway, so it definitely does well in that respect.
The reason it cuts the engine when pulling away with too few revs is to peotects the dual mass flywheel.
Driving in too high a gear with very low revs can also cause excessive wear on a dmf as it will overheat trying to damp out the vibes.
