alex16, I own a 2013 Mitsubishi Lancer SE and a 2015 Mirage ES. They both have the same oil and filter requirements with the only difference being capacity. I have used M1-110, WIX (Forget part Number) and Royal Purple 10-2867 filters. You will notice more power and better economy with the Royal Purple Oil filter over the other ones I have tried. The M1 is a great budget filter though. Make sure you don't use the OEM Filter the Mitsubishi filter is terrible for your car.
I have tried Castrol Edge, Nippion oil is what it comes from the factory with since Mitsubishi owns it, Mobil 1 Extended Performance, Mobil 1 Advanced Fuel Economy, PP and PUP. the two pennzoil products are the only ones that dont make weird noises in severe cold. I'm originally from lewistown PA (by state college) and I know it does not normally get as cold there as it does here in Lincoln so it might be okay but I do recomend you try PP and PUP. you wont be disapointed. you can get Pennzoil Ultra Platinum 0w20 from amazon for about $29 per 5 quart jug, since your mirage has a capacity of 3.2 quarts thats really a good deal. You can find PP for about $25 per 5 qt jug at walmart.
Here is a great comparison of oil filter for our Mitsubishi's. Totally worth a look.
http://www.evolutionm.net/forums/evo-eng...g63t-4b11t.html
Hope I have been of some help, I also hope you enjoy your new Mitsubishi and trust it will treat you well for many years to come.
