Re run viscosity on next UOA, or with current sample?Wear looks great and TBN very strong. The oil is now a 30 grade though. Without TAN and oxidation value it's hard to say. 15.33% change in cSt is a lot in just 5k miles. Not really sure. Run it again. Could be some cleaning going on. I’d ask BS labs to re-run viscosity.
I'd have them re-run this sample just to double check. B/S Labs isn't the most accurate.Re run viscosity on next UOA, or with current sample?
I believe so yeah. Around that.I agree with @buster isn’t there a VOA showing the starting cSt of 8.2 on this oil?
Edit: Here
https://bobistheoilguy.com/forums/threads/hpl-premium-plus-passenger-0w-20.385489/
Maybe it’s simply the nature of this blend. There is enough to combat the process to sludge; even with the oxidative thickening. We’ve seen this with HPL UOAs in several very long OCIs posted. As @SubieRubyRoo highlighted above BUT I do agree this much thickening in just 5k IS worth asking why.I believe so yeah. Around that.
Oxidation is something you don't want to see. It's as bad or worse than thinning. Oxidation is what leads to varnish, deposits etc.
Definitely. I removed my comments because I wasn't suggesting HPL would have this problem. It's loaded with detergents and high solvency base oil so in this case it's a non-issue. But for lesser quality oils I'd be a bit more concerned. But I would expect a premium oil to maintain its grade.Maybe it’s simply the nature of this blend. There is enough to combat the process to sludge; even with the oxidative thickening. We’ve seen this with HPL UOAs in several very long OCIs posted. As @SubieRubyRoo highlighted above BUT I do agree this much thickening in just 5k IS worth asking why.
If you used Amsoil SS before there should be nothing at all left to clean up. Was this engine run on Amsoil for a while or just one interval?this 3.5L (j series?) Honda engine is supposedly known for sludge given the variable cylinder management stuff. I am hopeful the HPL is cleaning some of this crap out. I’ve used amsoil SS before but switched recently to this stuff.
More varnish/lacquer than sludge, due to the heat.this 3.5L (j series?) Honda engine is supposedly known for sludge given the variable cylinder management stuff. I am hopeful the HPL is cleaning some of this crap out. I’ve used amsoil SS before but switched recently to this stuff.
This is a situation where you probably shouldn't oversimplify the explanation. HPL oils are simply very shear stable and as a result, "typical fuel dilution" will not be sufficient to mask the inherent thickening of oils as they age.HPL has told us multiple times that their oils are intentionally using the known properties of oils to “work thicken” in order to help offset fuel dilution.
Not the newer ones. Check out the photos I recently posted in the Passenger Car oil section.this 3.5L (j series?) Honda engine is supposedly known for sludge given the variable cylinder management stuff. I am hopeful the HPL is cleaning some of this crap out. I’ve used amsoil SS before but switched recently to this stuff.
Those pics look pretty clean! Have you done the VCM muzzler mod to your Acura? If not, WOW!Not the newer ones. Check out the photos I recently posted in the Passenger Car oil section.
UOA trends would need to be scrutinized.
Based upon personal experience with HPL PP, I would not freak out over thickening in this context.
Try 5W20 in the HPL Premium Plus favor. Go 10k.
