2014 Accord 4cyl using oil
Originally Posted By: deoxy4
Originally Posted By: ThirdeYe
My k24 burns about a quart every 1k miles. Just top it off and itll run forever.
605K miles awesome! At this mileage 1 quart/1K miles is probably normal due to ring wear. Did you ever need to replace a catalytic converter?
Do you remember what your oil usage was at 36K miles?
I did not own the vehicle at 36k so I cannot be sure what the consumption was back then. The catalytic converter is iffy. I replaced the front o2 sensor since it was throwing a code but it still comes on every so often for catalyst efficiency problems. My friend also has a 07 Accord woth the same engine but it only has around 150k and his only consumes maybe 1 quart per 6-7k.
How many miles a week?
I only drive about 20k a year. The bulk of the mileage was put on by the previous owner. Ive only had it for just under 2 years. The miles will be less now that I have a second vehicle to help absorb some of the miles as well.
