After seeing the other post on here, this got me thinking about the sonata, and its original transmission fluid at 48K and 7-8 years...
I have a couple questions regarding a ATF change on the 2.4L 2013 Sonata. It only has 48K miles on this car, but the fluid is original from 2013 so i'd like to change it out. I will probably use the OEM Hyundai fluid from the dealer, (unless you have a better recommendation) - I used Maxlife Synthetic in the 09 Elantra 3X3, and transmission feels amazing.. but i'd like to do at least 2-3 drain and fills on the Sonata to really refresh the fluid. There are no transmission issues im trying to address, it shifts fast, very smooth (almost too smooth) and direct, with quick engagements. I asked Hyundai how much to service the transmission and they told me $350
So i passed on that as i could do it three times for half the price.. So could i just drain the fluid out, measure and add what i take out, without ever opening the inspection port? If i did use the inspection port, can i just run the motor to get a warm again, and see where im at on fluid level, and add or let it drain as necessary? Any one have tips, pointers, words of wisdom? Hyundai says sealed for life, (unless you are willing to pay $350) and we all know what the means. I plan on doing a 3X3 to get it up to par, then drain and fill every 25-30K after, good plan? I dont think this 5 speed automatic is too hard on the fluid, (but you never know with all the computer controlled shifts, lock outs, and everything else that the computer will hide until its too late...)
i'd just like to know there is fresh fluid in the system, so i don't have transmission issues down the road.
Thank you all!
PS: all other fluids have been addressed already, I use 5W20 or Mobil 1 Extended Performance 5w30 synthetic @ 6K OCI, brake fluid was flushed this year (dealer), coolant was done recently (OEM fluid ) and no PS fluid because EPS
Thank you all!
