2012 Porsche Cayenne S - ATF fluid
Ndx
IL
Hello,
Any ideas what ATF I should be using? It's 8 Speed transmission by Aisin... TR-80SD I believe ...
Type IV
Type WS
OEM - VAG ?
Amsoil says use OEM
Redline says use OEM
Castrol Euro site says: CASTROL ATF MULTIVEHICLE - not sure if this is same formulation as US one.
Liquid Moly says TOP TEC ATF 1800 but then it says developed for ZF transmissions
Ravenol says: their T IV or WS but aren't they totally different fluids ..
I'm pretty confused as you see
Thx guys
Manual says nothing .. It's "lifetime fill"
The bottle that I bought at dealer was VAG branded G-055-540-A2 Madd in Canada... for VAG does not say by who...
Originally Posted By: montero1
People have been using different types in those Cayennes. Mobil 3309, T-IV, Redline D4 and D6.
From everything that I can see proper fluid is the WS
The fluids referenced above were probably used on previous generation ... not 8 Speeds
Looks like OEM Aisin WS fluids are around 10/qt so that's pretty good ...
Has anyone used the Aisin branded fluids ?
Searching for transmission name does not yield any results
Originally Posted By: Ndx
Hello,
Type IV
Type WS
OEM - VAG ?
Amsoil says use OEM
Thx guys
I would use the Liqui Moly oil, BUT send them an e mail as a cross check and make 100% sure you use the US page of the LM web site and enter the correct engine code.
Since car is "german" I would use german LM page
Dont worry...they understand english language...and they also speak it quite well (been there...done that every time)
