2012 Hyundai Accent Uoa 1,6L GDi w PUP 5w30/20 mix
Kansas (316)
Lab # H26771
Code 20/32
Report Date 1 15 2016
Miles on oci 3859mi
Miles on motor 194209
Aluminum 4 Avg 3
Chromium 0 0
Iron 8 9
Copper 1 1
Lead 0 0
Tin 0 0
Molybdenum 226 292
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 2 1
Potassium 0 0
Boron 213 355
Silicon 5 6
Sodium 4 7
Calcium 2063 2364
Magnesium 4 10
Phosphorus 644 696
Zinc 734 847
Barium 0 0
Sus Viscosity at 210F 59.5
Cst at 100F 10.07
Flash 400F
Fuel Antifreeze 0
Water 0
Insoluble 0.3
Blackstone Report of 2 Pennzoil Ultra Platinum 5w30, 1 qt 5w20 Pennzoil Ultra Platinum and 100 ml of LM Motor Oil Saver, 100 ml Ceratec and top off to fill line with Pennzoil Ultra Platinum 0w40.
Filter is Injen dry flow nano filtre with dry charger
Oil Filter was Napa Silver
Throttle cleaned prior with CRC IVD cleaner and fuel is E 0 87 Caseys with Gumout All in One.
Current fill is Pennzoil Ultra Platinum 5w30 with full bottle LM Motor Oil Saver and 30ml of Ceratec.
Notes._Wear metals are low here.Viscosity is in the 5w30 range. Low insoluble and silicon just like last time, shows excellent oil and air filtration. At this rate, another 200,000 miles should be no problem.
--Alex
OP, the UOA looks great but have you considered that this...
"2 Pennzoil Ultra Platinum 5w30, 1 qt 5w20 Pennzoil Ultra Platinum and 100 ml of LM Motor Oil Saver, 100 ml Ceratec and top off to fill line with Pennzoil Ultra Platinum 0w40."
...may be a little overkill for a 3,800 mile UOA?
But hey, if it works for you, who am i to discourage. Again, looks good.
Originally Posted By: Marco620
.Blackstone Report of 2 Pennzoil Ultra Platinum 5w30, 1 qt 5w20 Pennzoil Ultra Platinum and 100 ml of LM Motor Oil Saver, 100 ml Ceratec and top off to fill line with Pennzoil Ultra Platinum 0w40..
Its good to use only small amounts of those two additives, your 1/10 liter of each is smart. I'd stick to that. You're driving so much you could easily go to 10,000 miles on a full synthetic, but switch to Fram Ultra oil filters for more filtering efficiency, doesn't cost much more and is the best oil filter around.
