I used a hole on the front of the tranny (front of the car), it's a black bolt and is very short and looks like a plug for a filler hole. I should have used the fill plug on the side of the tranny, in front of and above the drain plug, but on the same end of the tranny as the drain bolt. I just went out in the dark after finally finding a schematic and realized I messed up. Tomorrow I will remove the fill plug and check the level. The fill hole I used was above the one I should have used so the oil level may be off. Could I have caused damage in doing this? I drove the car about 2 miles with the new fill. The oil drained very slowly and I wasn't there to watch it and drained it into a pan with engine oil so I don't know the amount that came out. I don't know what the hole is that I used but it is definitely on the transmission housing. Man I'm sick.
