Following the drain and fill for my 2011 Honda CRV. This is my 2nd one I believe Honda recommends 4. Used a new crush washer and added 3 quarts the same as last time. Following producedure after the fill I drove the car ran through the gears checked multiple times on level ground after the radiator fan turned on and waited 60 seconds. It looks like I’m slightly over. Honda says between the two dots. Cause for concern or no? I’ll be draining this again as I’d really like to change the filter while I’m under there.
