Originally Posted By: LS2JSTS
I'm curious why they picked a car with an X frame instead of comparing against the much more typical and far more common ladder frame with outside rails.
How much of a difference could that have made.
Not much difference, I suspect. With ANY structure not properly designed to yield to overwhelming "incoming" force, you're likely to get a poor result.
I do agree with you though, a modern unit body with crumple zones of lets say 3,500 lbs is safer than an old frame car of the same 3,500 weight. Crumple zones DO work, but in a Smart or other sub compact sized car, they are just too small.
But let's consider perspective. As an alternative to a motorcycle, the Smart is a superb choice. For a larger vehicle, maybe, maybe not. You have to remember that it's not just mass/size that's at play when vehicles collide -- there are probably thousands of other factors contributing to the outcome too. So long as your occupant space remains relatively undisturbed, and your decel forces are not too severe, you will survive a collision. A Suburban rolling over has as much potential to kill its occupants as does a small car hitting an obstruction.
