2011 Chevy Traverse, factory fill 69,787 miles
North Carolina
This is a friends Traverse and factory fill transmission fluid. It was pretty dark, not black and didn't smell burnt but dark. Considering the miles I thought it would be in worse shape. They do a ton of back country road driving and live 15 miles out of town. I was able to change out 5qts by pulling the drain plug and refilling it back up with AMSOIL ATL.
Code:
For a factory fill, this sample isn't too bad. Sure, aluminum and copper are high next to our universal
averages which show typical wear after ~25,600 miles, but they're mostly from the wear-in of new parts.
Some of it is from normal accumulation over the course of the run as well. Now that the oil has been changed,
we should see these metals and other wear in material start to wash out and read closer to universal averages.
We didn't find any contamination or insolubles. The TAN was fine at 1.5, low acidity. Check back without draining
after 30,000 miles. Not bad!
OIL Factory fill dexron VI
MILES IN USE 69,787
MILES 69,787
SAMPLE TAKEN 10/17/13
ALUMINUM 63
CHROMIUM 1
IRON 147
COPPER 229
LEAD 4
TIN 8
MOLYBDENUM 0
NICKEL 2
MANGANESE 15
SILVER 0
TITANIUM 0
POTASSIUM 5
BORON 44
SILICON 7
SODIUM 9
CALCIUM 78
MAGNESIUM 0
PHOSPHORUS 185
ZINC 13
BARIUM 6
INSOLUBLES 0.0
WATER 0
FLASHPOINT ºF 405
SUS VIS 210ºF 44.1 43-52
cSt @ 212ºF 5.43 5.1-8.2
Fuel%
Antifreeze% 0.0
Water% 0.0
TBN
TAN 1.5
