Hokiefyd
Initially, I was thinking that it was maybe something with the VVT system, the cams phasing or something. And I suppose that could still be it. But it sounds an AWFUL lot like spark knock. And I can induce it at will with the throttle pedal.
I've only owned one fuel-injected engine that pinged, and that was the 5.2L V-8 in my old Dakota. And it only pinged because the lower intake manifold seal was bad (pinging and oil consumption was a documented symptom of that). And of my carbureted engines, they'd only ping if the EGR was plugged or disconnected. After changing the water pump on my '84 Oldsmobile, I drove it 250 miles listening to it ping like a diesel until I realized that I left the vacuum hose off the EGR valve.
