This reminds me years ago I helped a friend put an OME lift on a '14 Taco and his front diff drain plug was rounded. I eventually drove a torx in and got it.Same plug STUCK in the Tacoma front differential. Use Al anti-seize.
My buddy had a reputable shop do the same re-gear and lockers as me to his Taco. After 1000 miles, time to swap "break in" gear oils. I was going to help him put in Amsoil 75W-90 in the front. Climb under the truck and the plug was completely buggered. The shop had done that! Yikes. We got it out, slot, chisel hammer..........and bought a new plug.This reminds me years ago I helped a friend put an OME lift on a '14 Taco and his front diff drain plug was rounded. I eventually drove a torx in and got it.
The key is a small to medium impact wrench and lots of pressure to discourage cam out. Quick blips of the trigger and hope (pray) to shock it loose. I got lucky but it was a fight and I now remember taking a B-BFH and going cave man on it to seat that torx after several failed attempts.
I have pretty good tools in my garage for a DIY guy, but no smoke wrench. I am considering the chisel approach. I will get another crack at the car next week.First, spray it up good with penetrating oil. Let it sit for awhile. Get the " blue wrench". Heat the plug up for a bit. Get a sharp chisel, lightweight hammer, and start making notches in different spots around the plug. Then just keep hitting the plug, where you started the notches, with the hammer and chisel. Slowly, it will start moving because there's a crush washer in between the plug and pan. Just be careful not to hit the pan. Oh, and make sure you have a new plug & crush washer.... LOL![]()
They sell 'em at the Gittin' PlaceI have pretty good tools in my garage for a DIY guy, but no smoke wrench. I am considering the chisel approach. I will get another crack at the car next week.
Thanks for your guidance.
Come to think of it, my BIL left one when he was here. Not sure I know which end is the business end...Yeah, just go to Lowe's or Home Depot and get a canister of propane, with any ole nozzle you can grab. It'll be in the plumbing section, in most stores, for sweating copper pipes together. Their cheap, and come in handy when working on stubborn / frozen nuts and bolts under the car. Rust under a car will make you're life miserable when trying to disassemble things. The blue wrench works wonders.
I appreciate your help. I also know my limitations. All good.You're sarcasm wasn't needed. I was just trying to help. Next time keep it to yourself !!!!!!!!
You could also buy one of the budget mini-ductors (I have one, it gets bolts hot) but honestly I've had so little success. It gets fasteners boiling off penetrant, but it just never seems enough. Maybe I just need to keep heating.I appreciate your help. I also know my limitations. All good.
My current plan is to use a chisel to break torque, and/or take it to a local shop, 2 of which are outstanding.You could also buy one of the budget mini-ductors (I have one, it gets bolts hot) but honestly I've had so little success. It gets fasteners boiling off penetrant, but it just never seems enough. Maybe I just need to keep heating.
Still, I'm glad to have it in the arsenal.
No flame so arguably safer than a torch.
