Have this thing I need to service. Is the filter a screen or a filter? Any good recs on aftermarket fluid?
Probably doesn't really need Dex VI, Stuff is expensive IIRC, many shops used DEX 3You should have the GM 6L45 transmission, which uses an actual filter, not just a screen. I just picked this up for my 2011 328i.
BMW GA6L45R Automatic Transmission Filter Kit - Genuine BMW 24152357284
BMW GA6L45R Automatic Transmission Filter Kit - Genuine BMW 24152357284www.fcpeuro.com
I also decided to use Valvoline full syn Dex VI.
This is the fluid I used,Probably doesn't really need Dex VI, Stuff is expensive IIRC, many shops used DEX 3
You do really need dex VI, and is it not expensive. It's just about the cheapest ATF you can get.Probably doesn't really need Dex VI, Stuff is expensive IIRC, many shops used DEX 3
I've seen guys using Dex III on the E90 forum, that said, I personally think the particular forum is full of questionable info and snobby posters. Just gotta be careful about who you believe in the internet.You do really need dex VI, and is it not expensive. It's just about the cheapest ATF you can get.
It’s been months since I bought a bunch … but price is holdingDEXRON-VI is a superior fluid in every respect to the old DEXRON-III license. I used VI in my BMW for many years until I switched to Maxlife, it worked fine.
That's an excellent price, even cheaper than Maxlife!
Yes, but you have to get it deliveredThat's an excellent price, even cheaper than Maxlife!
Just don't buy the gallon nor the 6-quart case
I got it from here, same stuff, same price. Might be helpful for any Prime members.
If you need the gallon, Maxlife is almost the same priceJust don't buy the gallon nor the 6-quart case
Yeah … on the Walmart stuff … got enough for the free shipping and have some left for my transfer case in the fall …Just don't buy the gallon nor the 6-quart case
Yes VI is specs better, I totally agree on MAXLIFE, I worked with a guy who owned a tranny shop for years, MAXLIFE was his go-to fluid. pay your money and do your thing, just saying lots of shops used DEX 3 without issue. Change more frequently which is a good thing.I've seen guys using Dex III on the E90 forum, that said, I personally think the particular forum is full of questionable info and snobby posters. Just gotta be careful about who you believe in the internet.
You don't have any BG/MOC in your toolbox that you can "donate?"Thanks folks......maxlife available for a reasonable price local
