Originally Posted By: Insane
....So, it seems the trend is to thinner and thinner oil. I'm not so sure I agree with that, but I'm curious as to why this is. Besides mileage gains of a thinner oil, I'm trying to figure out why newer vehicles seem to be moving away from the heavier viscosity. I somehow don't think engine longevity is really in mind when it comes to the manufacturers because no one keeps cars a long time any more, and the longer someone keeps an engine running, they are less likely to buy a new car.
Most all cars/engines are designed to last 150,000 miles, simple marketing demands that. Thats about 5-6 years of average consumer driving (yes, most people rack on more mileage than they realise!)The use of thinner oils is nothing new, aside from the obvious mileage savings from a less viscous oil, simply put, 20W oils are more than adequate for lube requirements. Most don't realise that cars made in the 30's and 40's usually spec-ed a straight 20W oil. Now granted, intervals for change were 1000 miles, but consider the technology of the oils back then, plus the 'dirty' gas used, amount and places people drove those cars (Sunday drive..), and the intervals about match what we have today. those engines ran their lifespan just as well on those 20W's. Now today, with oils technology unheard of back then, and engines burning cleaner than ever before, we put less strain on a better oil. Now clearances in those engines of old were really not much different than today, crack open a repair manual and you will see piston to wall clearances, and rod/main clearances very similar to todays engines, after all, .003" is still .003", whether its 1950 or 2010. Basic differences are
uniformity in those clearances. this is where I believe thicker oils were sometimes spec-ed in 50's- through the 90's engines. With todays more accurate uniformity in engine manufacturing, and way better oil manufacturing, 20W's are safe and reliable for todays engines.
My '06 Sonata came with 5w-20 when new. I had a few coupons for free dealer oil changes and they used bulk Shell Formula 10w-30. I went to PP 5w-20 at 20K. ( I change oil at 5K intervals)and at 30K, I went to 5w-30 Pennzoil Conventional. I do this because 2 other vehicles I own spec 5w-30, and it's just easier to stick with same oils for all of them. I would, however, have no second thoughts about running 5w-20 in the Sonata. If you still feel the 20W oils just bother you too much to use them, I would go with 5w-30, no higher.
