Originally Posted By: TrevorS
Another question, this conclusion that dino and synthetic are equivalent only applies in cases where the manufacturer spec allows a dino oil, right?
If the manufacturer spec necessitates a synthetic oil, would you still believe it to be possible that a dino could perform as well as a syn?
Rather than think about the German specs, how about Toyotas requirement of 0w20. In many cases, a 5w20 dino was previously allowable for those same engines. Would you have no hesitation in running a dino 5w20 in a 2014 Toyota that requires 0w20 for the same oci?
Not with the same OCI, at least with previous API SH, SJ.
Mercedes had to pay tens of millions back in 2000 to settle a lawsuit about sludge engines when owners used dino instead of synthetic with up to 15-18k miles OCI. The owner manual didn't clearly say that synthetic is required.
In case of Toyota, the OCI is doubled with synthetic 0W20. I think the main advantage of synthetic is longer OCI and extreme temperature. For normal everyday use in non-hostile environment and medium OCI, dino and synthetic are the same.
Side note, most of my stash are synthetic because it was cheaper then dino when I bought it.
