Car started idling rough and missfire at low rpm’s on Tuesday. Check engine light came on scanner gave me P0205 code. I checked ohms at the 3 injectors i can get to without taking intake off which is cylinders 4,5 and 6. Injectors 4 and 6 read 14.3 ohms and #5 is 246 ohms. I had cleared the code and car seems to be running normally. Car has 135k on it. What causes the high ohms reading? I run top tier gas but dumped a bottle if Chevron Techron cleaner in tank today. Could it just be a dirty injector and correct itself or is it gonna need replaced?
