200K Transition Mobil 1 To Amsoil
I’m not sure you’ll see any benefit going from EP to Amsoil. Especially going 5K on EP to 10K on Amsoil.
The Amsoil is a good product, but it’s not magic, and it won’t do anything drasticly different than M1. Sure, it has more additives (TBN), but depending on the EP grade the base oil is probably only marginally “better”. In a low performance Corolla that difference is largely irrelevant imo.
The EP is capable of 10K or more miles as well, that doesn’t mean you should do extended intervals however.
I would as suggested above, run your Amsoil at 10k intervals and call that good.
Anytime that you’re switching from one brand of oil to another I don’t think it’s a good idea to immediately start doing 15 or 20k intervals. There’s still some of the previous oil in there so that resulting mix of chemistry might not be up to the task of such a long interval. I would recommend doing a 10k interval first and get a UOA and then try 15k on the next interval. If that report looks good then consider doing 20k. The UOA is your best indicator of whether or not that interval is safe for your specific situation
Because this post was to get members jerked up with an amsoil - Mobil bash fest luckily it stayed sober.
Could very well be !
Doesn't mobil 1 EP carry the up to 25000 mile guarantee ?
I think who ever posted something smells fishy may be on to something.
Why would you screw with something that supposedly has ran 200000 trouble free miles ?
I know ! his money he can do what he wants
isn’t that what they’re all shooting for these days. Castrol and Pennzoil have the 20K claim. If Mobil has the 25K impressive
There are other reasons to get a filter cutter, Especially going extended drains.
That’s what my thoughts were but I wasn’t going to get involved OP knows what he’s got going on there. I would want to see how the filter is holding up look for silver flakes and fairy dust.
I have never gone over 5K miles on Mobil1 EP entire life of the car.
I drive over we 200 miles to and from work every day. I want to extend intervals and use best protection. Is 15k or 20k miles a good first interval with Amsoil?
Long time Amsoil user here.
In your position I'd sample the Amsoil at 10k (leaving it in), and extend further based on UOA.
Be certain to use a filter rated for 20k though...unless checking as suggested above.
I see you already have the AMSOIL, so best to use it, plus its a perhaps a better oil overall & for the long run ,over what you have been using. send in a uoa to a good lab around the 10 thousand mark and see how itis doing.
I have a stash of Amsoil filters and Mobil1 filters. Both should handle 10k miles.
I've never used Amsoil before. Feel it's a superior product
It may be superior, dunno. But it seems to me Mobil 1 has a pretty darn good track record. Our beloved 2006 Acura TSX has lived on M1 5w30 for the last 245K and does not go through a drop between 5K services. In fact, I use the MityVac to suck out the earl and swap the filter every 2nd service. I would drive this car to NY right now.
I did recently switch to Valvoline R&P, but that's mostly an experiment.
Regardless, good luck!
This is some inventory for a first time user
Yep. Until things get settled in the M&A world - many here are moving to PG/PG related filters for a reason …
Wonder who made those Amsoil filters?
Just now trusting M1 filters again …
