2009 Acura TSX: Very Disappointing
CA
This is EXTREMELY disappointing.
Acura is clearly going down the tubes. The second generation RL has been a total failure. The upcoming mid-model cycle refreshment of the RL still doesn't adequately address the issues that is preventing the RL from being a competitive vehicle.
Now, Acura has launched a TSX that has disappointed a very loyal family of enthusiasts. Many of us were hoping for the turbocharged engine from the RDX and a SH-AWD setup. This product launch only proves that Acura is unable to produce vehicles that will allow the brand to become competitive with BMW and Lexus.
Quote:
All-New 2009 TSX to Debut at New York International Auto Show
The second-generation Acura TSX is designed to appeal to young professionals with its keen-edge styling, athletic performance and advanced electronic features
TORRANCE, Calif., U.S.A., February 11, 2008– Designed and engineered to reaffirm its place as a desirable and affordable entry point for entry-premium buyers, the all-new second-generation 2009 TSX is larger, more agile, more performance minded and even “more Acura” than ever before. Carefully crafted to honor the original TSX’s vision as a world-class sports sedan, the new TSX has significantly evolved to offer more comfort, convenience, driving performance and safety. It does so with expanded luxury and electronic features, a wider stance for more agile performance, and advanced safety systems.
The 2009 TSX is expected to appeal to current TSX owners, young professionals and other image seekers who will appreciate its innovative styling, technical allure and total performance – while also valuing the outstanding customer treatment that owners have come to enjoy at Acura dealerships. Extremely brand conscious and eclectic in their tastes, buyers will find the TSX as satisfying for driving colleagues to lunch as it is for weekend snowboarding trips or vacation travel.
Powertrain
An all-aluminum DOHC i-VTEC® in-line 4-cylinder engine heralds a pair of firsts for the TSX model, including dual balance shafts and a direct ignition system. Along with improved performance, it is also cleaner as it now meeting the EPA’s aggressive Tier 2-Bin 5 and CARB LEV II Ultra Low Emission Vehicle (ULEV) standards for the first time in TSX history.
Displacing 2.4-liters and producing 201 hp and 172 lb-ft of torque (with manual transmission), the new in-line 4-cylinder engine produces its useable power across a much wider rpm range, while five percent more torque further strengthens the engine’s pulling power at middle rpm levels. This allows the 2009 TSX to be more responsive off the line and out of corners, and stronger in the middle of the rpm range where the engine operates most of the time.
This newfound performance and flexibility is due in part to a higher compression ratio, revised valve timing, and improved intake and exhaust gas flow. Further credit goes to the TSX engine’s i-VTEC® "intelligent" valve control system, which provides the power characteristics of a V-6 without sacrificing the light weight or fuel efficiency of an in-line four. Likewise, a new rear-mounted exhaust manifold layout, a close-coupled catalytic converter design, and a Programmed Fuel Injection (PGM-FI) system substantially reduce emissions levels. Estimated fuel mileage is 21/30/24 mpg* (city/highway/combined, 5 AT) and 20/28/23 mpg* (city/highway/combined, 6 MT).
Two transmissions are available, both as standard equipment – a 6-speed close- ratio manual with new performance-oriented ratios for Second through Sixth gears, and a Sequential SportShift 5-speed automatic with a new lock-up torque converter assembly. The manual transmission features a short-throw shifter with a precise, light action that makes it highly rewarding to use, while the Sequential SportShift automatic permits fully automatic operation with intelligent features such as Grade Logic Control and Shift Hold Control, which make driving the TSX on hilly or winding roads more enjoyable. If the driver desires, the automatic transmission can also be operated manually via new steering-wheel mounted F1®-style paddle shifters.
Body and Chassis
The 2009 TSX body structure includes two firsts for the Acura division, including a closed-channel cross-braced roof structure and inside frame rails. Along with a stronger rear bulkhead, the closed-channel cross-braced roof structure yields a more rigid and vibration-resistant structure. The first use of inside frame rails for any Acura model help tailor the aerodynamics underneath the car for improved fuel economy, lower emissions and reduced noise. In addition, new A-, B- and C-pillar separators improve the TSX’s quietness over rough roads and at high speed. Slippery aerodynamics also helps fuel economy as well as high-speed stability – all while lowering emissions.
In addition to its 3.0-inch greater width and 2.6-inch wider track, the 2009 TSX has a 1.3-inch longer wheelbase and 2.4 inches more overall length. These dimensions combine to provide greater interior roominess, more agile handling and improved ride quality. Another first for Acura are the TSX’s new dual-mode suspension dampers, which provide superior suspension damping characteristics at both lower and higher damper speeds. Using a unique deflector plate stack, the new dampers adjust compression damping characteristics to suit the vehicle speed, cornering forces and road surface. In creating the second-generation TSX body design, Acura designers sought to retain the crisp, dynamic design of the original and enhance it by widening the body overall and adding more muscular and distinctive cues to create a keen-edged sports sedan. Their key design goal was to create an aerodynamic design that evokes both emotion and tension with a decisively sporty flair.
Outward visibility is improved with a slimmer A-pillar design, while an auto up/down front passenger window adds convenience and a reverse-linked passenger-side door mirror tilts down to help improve safety while parallel parking. The new TSX also has a wider trunk opening and a lower trunk lift-over height for more convenient loading.
Exterior/Interior
Functionality and refinement converge with luxury and style in the interior of the 2009 Acura TSX. Featuring a blend of sweeping, contemporary shapes, a high level of standard comfort and convenience features, widespread use of premium materials and an available Technology Package, this 5-passenger sports sedan offers the upscale modern interior that customers have come to expect from Acura.
From the precision-crafted metal door sills to the satin-metal finish accents, from new leather-covered seats to the steering-wheel mounted controls, and from the premium 7-speaker sound system to the dual-zone automatic climate control, the TSX represents a merge of intelligent design and innovation. For example, Bluetooth® connectivity is standard and includes a HandsFreeLink® cellular telephone interface that makes communications easier and safer while en route.
Typical of Acura, the TSX offers an exceptional level of standard equipment. Included are a standard power passenger seat, a new folding key with remote entry, new automatic headlight activation, a premium 7-speaker sound system with CD, AM/FM/XM®, Bluetooth® HandsFreeLink® , and USB port music interface. A HomeLink® remote control system is also standard.
Adding to the already impressive list of TSX standard equipment is the available Technology Package, which bristles with leading-edge electronics that make driving much more efficient and enjoyable. These include an Acura Navigation System with Voice RecognitionTM, AcuraLink® Real-time traffic, AcuraLink® weather, and the highly useful AcuraLink® Satellite Communication System. The navigation system also features Real-time trafficTM covering 76 major metropolitan markets, and offers Traffic Rerouting with dynamic route guidance to help navigate around slow-downs. For 2009, the TSX receives a dash-mounted electronic compass for added directional information while driving.
Included in the Technology Package is a premium sound system tuned by legendary sound engineer Elliot Scheiner. This 10-speaker Acura/ELSTM Premium Surround Sound System with DVD-Audio includes a new Note function for XM® Radio that makes it easy to identify songs to recall at a later date. With push of a button, the Note function can capture 10 seconds of up to 30 songs, along with noting text indicating song title, artist name, and XM® channel.
Safety
The 2009 Acura TSX leads the way in safety with its new Advanced Compatibility EngineeringTM (ACETM) body structure. Engineered into the TSX model for the first time, ACETM improves the dispersal of frontal crash energy through the use of load-bearing frame structures that better match the TSX with other vehicles of different sizes and with different bumper heights. Simply put, ACETM helps maximize the effectiveness of the TSX’s front crumple zones, better dispersing crash forces before they reach the passenger compartment.
A broad range of passive safety features likewise contributes to occupant safety, including six airbags (dual-stage, dual-threshold front airbags, new dual-chamber front seat side airbags, and side curtain airbags for outboard seating positions). Three-point seatbelts and head restraints are provided in all seating positions, and front seatbelt load limiters with an integrated automatic tensioning system further protect the TSX driver and front passenger. A new Active Headrest Restrain System is used for the first time on the TSX, while the rear seat features a Lower Anchors and Tethers for CHildren (LATCH) system that allows for the easy and secure affixing of up to two child seats. Exterior features designed to further improve safety include daytime running lights (DRL), pedestrian-injury mitigation features such as a deformable hood, hood hinges and windshield-wiper pivots, and a 5-mph front bumper and 2.5-mph rear bumper. The 2009 Acura TSX is expected to achieve the highest ratings in both government (NHTSA)** and independent (IIHS) crash testing – including garnering IIHS’s TOP SAFETY PICK.
Finally, the 2009 Acura TSX is covered by a comprehensive 4-year/50,000 mile bumper-to-bumper limited warranty and a 6-year/70,000 mile powertrain limited warranty. Additional benefits of ownership include Acura Total Luxury Care® (TLC®) that provides free 24-hour roadside assistance, concierge service and trip routing.
"The 2009 TSX is expected to appeal to current TSX owners, young professionals and other image seekers who will appreciate its innovative styling, technical allure........"
Image seekers?
I'll stick with my ugly, old, technologically ancient, TROUBLE-FREE Legend, thank you.
Image seekers?
Every time I look at the pic of the new car, I see Bonneville. I'd swear the grill came right off the latest Bonneville.
I too would love a Legend. The last-gen coupe please.
Agree on the disappointment. If I am shelling out a almost 30k, I would expect at least some goodies like V6, RWD, turbo, high MPG or something like that. This car should be the US accord rather than TSX.
I'm more of a person that like cars for their appearances first, performance second, and then the rest. The 09 TSX front fascia looks like an offspring of a Camry and the Saturn Aura. If they sell it as the Accord in Japan and Europe, why do they need to sell it as a higher level car here?
Acura marketing bee essence pretends Euro/JDM Accord never existed, and the TSX was invented just for North American yuppies to take on BMW. That's lame, but that's marketing.
On its own merits, the new car seems nice enough to replace the old TSX. Maybe after a couple of years there will be a Type-S version with more pep. Honda is a very cautious company...
I look forward to having a diesel wagon TSX some day (but I don't see either wagon or diesel fitting in with Acura marketing's idea of sport-luxury). Their loss.
I'm telling you some kind of sheetmist of LeBaron/Buick/Pacer styling has crept into to the auto styling wing of Honda and Acura. Reminds me of a trip to that island on Spirited Away after a three day MD 20/20 binge.
Well, the current crop of BMWs isn't particulary eye-catching either, although that's a personal preference I guess. There seems to be a competition in who can design an uglier car.
Image seekers?
I love Legends, I test drove one before with around 100k on it, it was like new for being 12 years old at the time, if I remember right. I thought the coolest thing was the power cupholder on the armrest, plus the power from that engine was great. I was at 70 before I even knew it. But like you, I'll stick to my old trouble-free Acura!
Nothing has really gone wrong on the car since I've had it. Just replaced a few old leaky seals (spark plug tubes & cam plug, common on all B18 motors over time) and the thermostat. The rest has been maintenance. Great cars.
Wow. How exciting. The Acura brand name continues to throw more balls than strikes. They took a brand that generated a lot of excitement in the early 90's and wasted it by developing too many boring cars. People are still passionate about Legends and Integras. But no one cares about RL's and TSX's. Nice cars, but boring.
I just don't get it. Say the word Lexus to the average Joe and they know right away. Most people don't know what Acura is, though. Piddling away the brand image and designing boring cars isn't helping things at all. Acura sales were down 13% for 2007.
Our division needs some excitement, like in the early to mid 90's when the 2nd gen Legend, 3rd gen Integra, and NSX came out. Those were some good times.
I dont know about the looks, but 201hp from a 2.4L i4 NA is pretty impressive to me. No need for a turbo.
looks like the new malibu and aura. bOOOOOOring.
my supervisor has a TL type S, that's pretty cool, but still doesn't excite me.
Maybe, but RWD would be nice at least!
To be fair, Lexus cars aren't exactly all that exciting either, apart from the IS maybe. They were not meant to be exciting. The goal is to totally isolate the driver from the road. When you set a goal like this, you score big on the luxury scale, but forget about driver involvement or any kind of excitement.
But at least the IS is RWD. Whereas the TSX is perceived as nothing more than an expensive version of the Accord. The rest of the world doesn't have that problem as the Accord is the TSX over there.
