Z ZZman Joined Mar 17, 2008 Messages 8,779 Location Michigan Aug 30, 2017 #1 Just changed the plugs and PCV valve in the wife's car. What a hassle! 1. PCV valve is located under the intake manifold. 2. Intake manifold needed to be removed to do back 3 plugs. Thank you Youtube!
A ARCOgraphite Joined May 17, 2009 Messages 22,440 Location N.H, U.S.A. Aug 30, 2017 #2 how was the pcv valve? Gunky? - usually a solvent cleaning will set her right. That wont fix a cracked hose though.
Z ZZman Thread starter Joined Mar 17, 2008 Messages 8,779 Location Michigan Aug 30, 2017 #3 It still rattled but was oily of course.
S slacktide_bitog Joined Mar 20, 2008 Messages 19,276 Location USA Aug 30, 2017 #4 I hope you used NGK iridium, and that you also replaced the valve cover gaskets
Z ZZman Thread starter Joined Mar 17, 2008 Messages 8,779 Location Michigan Aug 30, 2017 #5 Originally Posted By: slacktide_bitog I hope you used NGK iridium, and that you also replaced the valve cover gaskets Oops.. Autolite Iridiums and no valve cover gaskets.
