2007 Ford Fusion 200,000K evaluation
Illinois
The Fusion turned 200K today. This car has been the most reliable vehicle I have ever owned. I change oil every 10K using Mobil 1 0w20 Advanced Fuel Economy, and the engine uses no oil between changes. Engine and trans(drain and fill every 30K with Mobil 1 ATF) perform as well now as when I bought the car with 38K. Few parts have been replaced. No rattles and car handles very well.
Parts:
2 water pumps
Front and rear brake pads
Only suspension parts replaced was one front strut
One air pump and one sensor for fuel evap system
Replaced one panel on the front drivers seat
Replaced the accessory belt and tensioner pulley
Replaced the engine coolant thermostat
Replaced a sensor for the AC
Replaced the VC gasket
What does this mean? Fabric? How did you replace it?
Parts:
2 water pumps
what is the VC gasket ? can you be more specific on the panel ?
I have the same car, what is the gas millage ?
tig, surely you must tell us the secret engine drain n fill every 30k with automatic transmission fluid that you've been doing all these years. Seems to be working well for you and I'd like to maybe implement it into my maintenance routine as well. I want my beater to make it to 200k like yours...
2007 fusion se 2.3l/5sp slushbox
240-250k range, 26k at purchase.
List of repairs/parts:
1) drain tube (a/c)
2) 2 batteries
3) smog pump
4) thermostat and make-up (partial FF)
5) 4 sparkplugs
Maintenance:
1) Dealer oil package
Mobil conventional bulk 5w-20 and mobil filter
5-12.5k on services, no used oil analysis
2) many front pads/rotors
2 set rear pads/factory rotors
3) many tires
Thats it, factory steering / ac / suspension / fuel system / atf / heating
harvey
Tig - I'm kind of surprised at the two water pumps - other than that, impressive. I'm guessing you replaced the plugs at least once. How much longer do you plan to keep it - 300K?
One water pump would not be unusual - we arbitrarily changed one on 3.5L Mopar while doing the timing belt - figured that was $100 incremental shooting for another 100k on top of the 100k at the time ... that's how PM works ...
These cars seems to be reliable! 251K on my family's 09 Fusion V6 and repairs have been minimal for the miles. It was a shame that the car was almost a total loss when 2 years old but I saved it.
Ford apparently got this car just right.
This is a real testament to the quality of Ford's US offerings. I doubt that any car from any maker would have done better.
It's also hard to argue with your use of Mobil 1 Advanced Fuel Economy. While I've chided you in various threads about M1 versus other brands, it's clear that the oil has performed well for you on longish drains.
How long will you keep this old dear?
Didn't Ford market this car to compete with the Camry and Accord? They did a good job for once IMO.
Yes, the first panel on the bottom of the seat. $120 at an upholstery shop.
Parts:
2 water pumps
Valve Cover gasket. This is the 2.4 I4. I get about 24-26 local and about 31-
33 Interstate.
Like I said I do a drain(pan has a factory drain plug)every 30K and every 60K I drop the pan and change the filter. Even though Mobil 1 ATF is not on the OK list for my Fusion(FNR-5)that's what I use and the trans upshifts and downshifts great.
