Originally Posted By: Balrog006
Keep on top of the transmission fluid changes, not that it’ll cure or prevent catastrophic failure if one is eminent but it’ll keep the trans happy otherwise.
130k? Has the timing belt and water pump been changed? The Honda J35 V6 interval is 105-110k Miles and it’s a ~$1K Service. A tune up/new plugs are due at the same time, those been done yet?
The cabin filter is a bit of a PIA to change especially at first, but still somewhat of a complex thing for a cabin filter and probably takes 10-15 minutes.
Dealer will likely recommend “compliance bushings” for the lower front arms based on mileage, be sure to inspect them for actual damage before having that done, watch for the tie rods loosened up as well, they’ll cause a “clunk” when turning or over bumps.
Other than those, the platform is durable, efficient and fairly easy to do basic maintenance on.
I will be doing the timing kit in 2 weeks, along with plugs, filters, oil change,vtm fluid change, and balance/rotate the tires. Im fortunate enough to have my own tire machines in my home garage. Timing kit will be easy enough. Ive done at least 50 Honda belts, just never one on a Pilot,but mot expecting any issues.
While I'm at it, I'll give the suspension and steering a good check.
Thanks everyone!
