2006 Chevrolet Equinox MIL Codes HELP!!
Chicago, IL
2006 Chevrolet Equinox AWD
160K miles, almost at 161K
Check Engine Light is on
Codes are:
P0120
P0700
P1125
P2138
I need background information from the BITOG team on these codes.
Any help is greatly appreciated from you guys.
Originally Posted By: zvm77us
probably need a new throttle position sensor in my opinion.
agreed. TPS code with an a TCM MIL request code and Limp Home. The malfunctioning TPS has created poor fuel metering and the vehicle went into limp home to prevent engine and transmission damage.
When I googled those 4 with that year it says check for corrosion in the connectors.behind the kick panel
usually due to sunroof leaking.
