Just finished doing an afm delete on a 2014 sierra l83 with a LOT of help from clinebarger.It fired up quickly with almost immediate oil pressure and runs smooth as silk but the check engine light is on and codes P0300 and P0138 are showing as permanent on the scanner.I ran it for 20 minutes so the new springs would break in properly and watched everything for leaks ,temp,oil pressure ect and all good.The afm function was shut off prior to me getting truck with an hp tuner.I understand that even though its shut off i need more done via the tuner and i'm wondering if these codes are part of it .I'm very limited in my tuner knowledge and i live in a small area in NB Canada where nobody i have talked to has done one of these deletes.Diesel deletes are common place as we are a farming area but the gassers just get put back to oem so the bombs keep on ticking lol.I know a guy who does some stuff with an hp tuner but he has never been into one of these and not sure if he even will.Am i going to hurt the motor by running it until i can get this figured out.Ps could not enough backpressure cause the o2 code as a previous owner removed the muffler which i haven't addressed yet?
