2005 Silverado using some oil
I can't promise I'll do 4 oil changes with it but I'll try. 4 changes will take 20-25k miles. I plan to do them at 5k but sometimes dont get to it until close to 6K. Would be nice if it burned less oil at that time. I just don't know if i can spend that kind of money. I can't see how this stuff is so expensive. It must be all the marketing and expensive lawyers or something.
Again, the truck is great otherwise. I've had to do the normal stuff over the years like suspension, front end, wheel bearings, AC and parts of the exhaust. But its been really inexpensive to fix and my local corner mechanic does everything i can't or don't feel like doing now that im getting older. If the engine does get too tired, I'll put on some performance heads and maybe a cam to wake it up a bit. It's basically part of the family, so won't me going anywhere.
If it were mine I’d buy the absolute cheapest syn blend I could find, or maybe even conventional because with the age and miles and being the engine that it is, it doesn’t much matter what you use as long as it’s in there. I’d run my real cheap oil a 3k mile OCI and be good to go another 150-200k miles
Pcv valve?
A plugged up valve will use oul
Not sure if 2005 had the Olds design w/the ball or the or new design without the ball and just a hole
I had a 2002 4.8 and have a 2003 5.3 and a 2006 5.3
Truck most likely needs an updated valve cover with the revised PCV system. The first couple valve cover revisions were bad at just consuming oil.
I have a 2005 Suburban 1500 Z71 with the OE L59 (flex 5.3). Everything OE. 255k on the odometer. Thew a revised/last revision valve cover on it along with a catch can a few years ago. It’s lucky if it uses maybe a 1/5th of a quart over 3k miles. And the catch can collects maybe 2TBSP.
Don’t know if I’d figure it’s worn out already. The Gen 3s were some strong engines.
Update: I am 3000 miles into my first OCI with the valvaline restore. Still using oil at the same rate.
From reading other experiences on this site with the Restore Protect, you may not see results until 3rd or 4th usage. That’s a good truck you have, worth keeping. Not having the switchy 4cyl junk is a big pro. My 15’ with the Ecotec3 burned oil with the 20 grade stuff. Much less using x-30.
Dont be surprised if it may get worse in the 1st one or two oci's then get better and/or stop, it did with me and many others. Valvoline Restore and Protect oil isn't expensive and the cost of makeup oil offsets the price. Keep at it
I had a 2000 Chevy Silverado 5.3 155,000 miles it had a hairline crack the size of a pencil eraser at 13 years old in 1 cylinder head.I purchased remanufactured cyl. heads,the manufacturer claims any valve guides out of spec. are replaced along with all new valve stem seals.My oil consumption went from 4000 miles to a quart,which I consider good to using 8 ounces in 4000 miles.I guess new valve stems seals make a big difference!
Well, using that oil is still cheaper than a car payment. You can go your regular 5000 mile oil changes if you want, it won''t hurt anything.
AND be sure to change the oil filter too. If there is junk to clean out, that's where it will end up.
THEN, for us on this site, it would be nice if you would cut the oil filter open for us to see exactly how effective the new oil was.
Thanks
  • Like
Reactions: wlk
