I have an 05 Honda Civic (5spd) and want to know if this car needs to have the differential fluid changed. I recently changed the transmission fluid but wondered if the axles shared the same the same fluid as the manual transmission. Thanks.
By changing the MTF you've done what's required fluid wise. The fwd system that includes the front axle runs of the transmission so your fine.
Did you use Honda mtf or go with another fluid?
