Originally Posted By: robd
Update, The truck was not driven very much when the noise was first noticed, lately I have been putting about 50 miles a day on the truck and noticed that the startup tick is almost gone. Looks like it was a lifter sticking.
Now I will be getting the truck ready for the summer camping season and I was wondering if maybe a heavier oil shoud be used when towing our 7000 lb camper. Maybe I would be better off using a 5w30 in the summer? Truck specs 5w-20 for all temps. Any info would be appreciated.
1 - I would add some Seafoam 50-100 miles before you plan to do your next OC and it should help finish freeing up whatever was sticking. It is very good stuff and works wonders.
2 - 5w30 is actually fine year round for your 05 5.7L even though it spec's 5W-20 if you wish to run it. You can even run 10w30 in the warmer months if needed and do no harm. The move to 5W-20 away from the previous 2003-2004 30 weight recommendations in 05 was strictly for CAFE reasons and no other. The ONLY 5.7L from 03-08( in 09 they redesigned the 5.7L )that "NEEDS" 5W-20 are 06-08 years that have MDS. Otherwise a 30 weight can be run with no "mechanical" issues.
Dodge has really flipped around on the oil spec on the 5.7L from 03-08 despite the engine basically being the same except when MDS was added in 06( 1500's only ). From 03-08 the 5.7L was the same basic motor either w/ or w/o MDS( 06-08 )so you can run 20 or 30 weight oil in your 05 2500 as you do not have MDS to worry about.
Here are the oil recommendations by year just to show you what I mean( again same engine just w/ or w/o MDS in 06-08 )...
2003 = 5w30 or 10w30( not below 0 F )all model Rams
2004 = 5w30 or 10w30( not below 0 F )all model Rams
2005 = 5W-20 all model Rams
2006 = 5W-20 all model Rams
2007 = 5W-20 all 1500's(MDS), Mega Cabs, & HD's under 14000lbs GVWR / 5w30 HD's over 14000lbs GVWR
2008 = 5W-20 all 1500's(MDS), Mega Cabs, & HD's under 14000lbs GVWR / 5w30 HD's over 14000lbs GVWR
