ls1mike
$50 Site Donor 2026
What is the general consensus on these? I found a nice clean one with 120,000 miles on it with maintenance records. How is the 3.5? As I recall really good, but wanted to the thoughts of the group here.
The transmission is my main concern. I had a Honda many years ago and the transmission was the weak point. At the price point it is at I may skip it. Thanks ctechbob!The engine will be solid. It's a non-VCM J-series. Regular maintenance will take you a long way.
I don't know a lot about the trans on that car though. 2005 is still in the area where Honda was doing the 3 shaft units, which are meh, on a good day. With the AWD system I'm just not sure what they were using for the trans.
Some quick and dirty research shows that it should be a 3 shaft. You can usually expect a rebuild on those anywhere between 100-150k, even with religious maintenance. There are some design flaws that no amount of fluid changes will cure.
The rest of the car should be solid. Although, it looks as though they use a similar front control arm as the TL's did, look at replacing the compliance bushing in the arms as those don't last forever.
Yea, I just had the 3 shaft in my Accord built. Cost was around $2k. The guy that does them for me said that they are getting harder and harder to build. Most of the time the case is trashed to the point where they have to find a new core, and those are starting to dry up. Apparently one of the shaft bearings likes to start beating up the spot on the case it mounts to and trashes the case.The transmission is my main concern. I had a Honda many years ago and the transmission was the weak point. At the price point it is at I may skip it. Thanks ctechbob!
do you REALLY need a 7th vehicle to buy, insure, maintain ?What is the general consensus on these? I found a nice clean one with 120,000 miles on it with maintenance records. How is the 3.5? As I recall really good, but wanted to the thoughts of the group here.
Not really an issue for me because 3 of them are really the only ones that get driven and they are all paid for. His truck would be parked, just not willing to sell it as he will take when leaves the house and this car will become my daughters.do you REALLY need a 7th vehicle to buy, insure, maintain ?
I believe those RL's used a unique lower control arm that is aluminum and dealer-only. The engine/trans should be as reliable (or not) as any other non-VCM J35, but the rest of that car kinda scares me since it was a very low-volume niche car that was designed to compete with the 5-series (and similar). Getting parts for anything other than the engine/trans can get weird at this point.The rest of the car should be solid. Although, it looks as though they use a similar front control arm as the TL's did, look at replacing the compliance bushing in the arms as those don't last forever.
Critic, thank you very much. I passed on that car. The search continues. I was trying to branch out and try a Honda/Acura/Toyota/Lexus. You pay a premium for them. I found a 2007 Lacrosse with 110,000 miles/3800/4T65E, all service records to include two transmission fluid pan drop and fills, intake gasket at 80,000 and few other small things. Fully loaded for 3800 bucks. I am going to look at it today. Original owner who ordered it new. Might take a chance on that one as I am really familiar with that drivetrain.As suspected, no aftermarket front lower control arms available. Dealer only, list is $798/ea. Honda has started to discontinue parts for cars from that era, even for the high-volume models, so....buyer beware.
IMO that is a better bet. You know the platform better. JMHO but I think jumping ship will have you tossing wrenches at the wall and second guessing yourself.Critic, thank you very much. I passed on that car. The search continues. I was trying to branch out and try a Honda/Acura/Toyota/Lexus. You pay a premium for them. I found a 2007 Lacrosse with 110,000 miles/3800/4T65E, all service records to include two transmission fluid pan drop and fills, intake gasket at 80,000 and few other small things. Fully loaded for 3800 bucks. I am going to look at it today. Original owner who ordered it new. Might take a chance on that one as I am really familiar with that drivetrain.
I've had good luck with the 3800's I've owned, 91 Park Avenue, 99 LeSabre and now my 08 Lucerne.Critic, thank you very much. I passed on that car. The search continues. I was trying to branch out and try a Honda/Acura/Toyota/Lexus. You pay a premium for them. I found a 2007 Lacrosse with 110,000 miles/3800/4T65E, all service records to include two transmission fluid pan drop and fills, intake gasket at 80,000 and few other small things. Fully loaded for 3800 bucks. I am going to look at it today. Original owner who ordered it new. Might take a chance on that one as I am really familiar with that drivetrain.
I have had a few S/C and N/A ones. 1998 Bonneville, 1998 Regal GS, 2001 Grand Prix GTP, 2005 Grand Prix Comp G. They always treated me well. I did a few intake gasket, coolant elbows, and various small things here and there. So this one might be worth it for me. I think by 2007 the 4T65E had all the updates. I have replaced two of them one in the Regal early on like 60,000 I think it was service improperly, and one in the 01 GTP it was modified a bit and made it to 210,000 where I killed it at the track.I've had good luck with the 3800's I've owned, 91 Park Avenue, 99 LeSabre and now my 08 Lucerne.
I laughed at this because my buddy said "Man you know I am Toyota guy, but the first one you buy will be not be correct and you will be angry for life" LOLIMO that is a better bet. You know the platform better. JMHO but I think jumping ship will have you tossing wrenches at the wall and second guessing yourself.
In the meantime, can you let me know if you come across any 25 year old Camrys? I could use another one… j/k. Good luck.
I had an 06 accord 3.5 that went to 325k kms.What is the general consensus on these? I found a nice clean one with 120,000 miles on it with maintenance records. How is the 3.5? As I recall really good, but wanted to the thoughts of the group here.
