Hey guys,
I bought my 2005 Crew Cab Silverado (5.3L gas) in 2010 with about 89K miles. I am pretty sure that the previous owner said that he changed all fluids at some point with AMSOIL. Fast foward to now, it has 197K and I have changed every fluid other than the trans fluid, which is still in 'good visual condition'. Nice red color, no burnt odor. My plan was to change out a couple quarts with each oil change. Here is my question-
GM started using Dexron 6 in 2006 as far as I can tell, and advising backwards compatibility with Dexron 3. I do not know if the previous owner used 6 or 3 when he serviced it. I am assuming the best choice here would be to use Dexron 6? I would like to take advantage of some of the Valvoline Dexron 3 on clearance at Walmart, but if not I'll survive.
Thanks
Travis
Thanks
Travis
