Hello,
Been Lurking on this forum for a while and decided to join in and get some valuable tips from you guys. Bad news is I am not very handy with a wrench and do not do my own oil changes and maintenance.
My 2004 Tacoma is gladly paid for and would love to drive it for many many more years. Most of the maintenance that has been done on it at Toyota and it has received a blend oil and Conventional oil in its life. The truck is almost at 99k miles and would like to know what, if anything, I should start doing to make sure it last another 100k miles. The truck seems to be running fine as far as I can tell with my limited knowledge.
Last year at this time I ran 1/3 Can of SeaFoam through brake booster air line, rest of can in full gas tank. I got a pretty big smoke show, but honestly I did not notice any idling or performance difference.
The next thing I am going to try to do myself is clean the MAF Sensor. I got a can of CRC MAF Cleaner and instructions I have found make this look pretty easy. I also bought a can of SeaFoam Spray Deep creep and may try to clean throttle body myself. Do you guys suggest I do both of these? Pretty Easy Right?
My MPG is 15-17 in city right now and 19-21 on Hwy. I would love to get that up a couple of MPG's if possible.
Here are the things I am going to try based on reading this forum. Please let me know if I am on the right track with any of these or if they are a waste of time or can I do something else or better?
1. Go to Mobil 1 Synthetic EP. Change oil between 7k and 10k.
2. Keep using factory Toyota - Denso Large Oil filter.
(This or any Oil filter going to be ok for up to 10k?)
3. Run some type of Oil Additive right before I change my
oil to the Mobil 1? Which one?
4. Use a can of BG44k in fuel at this oil change and then
Redline SI-1 every 3rd or so fill-up.
5. Any special air filter help on my truck outside of factory?
I do not want to mess with oiling filter and I would
prefer my truck not to get louder.
6. Anything else I should do?
Sorry for the lengthy post, but I wanted to be as detailed as possible. Most importantly, I want my truck to run great for years to come and would love to save a few dollars on fuel in the long run.
Thanks in advance for all replies, advice, and suggestions.
MC
MC
